Top Speed on 6MT coupe???
Old Feb 28, 2005 | 03:36 AM
aren21's Avatar
Question Top Speed on 6MT coupe???
Hey everyone, Im trying to make up my mind between the G35 and 350z, and im really leaning towards the G35 because of its looks and added luxury. I know the performance numbers between them are pretty similar, but I was wondering what the 6spd coupe tops out at. Same as the Z or what?
Thanks for the help!!!!
Old Feb 28, 2005 | 08:42 AM
dentalstud's Avatar
20 Year Member
Close enough to the same, I believe they are both governed at 156. But honestly, if THIS is what is going to change your mind for one car over another, you need to be looking at other models....
Old Feb 28, 2005 | 09:14 AM
Hotrod's Avatar
Whats the difference, they are very close and you will never know the difference if it's one or two mph off because, really how many times will you drive it that fast and for how long will you be able to hold that speed?
Old Feb 28, 2005 | 12:55 PM
Rated PG 35's Avatar
they'er almost the same car, just the z tube is missing in the g35. Other than that it's identical in parts, but not style. Are you going for sport, or luxury/sport?
Old Feb 28, 2005 | 01:26 PM
heeb's Avatar
My G went to 155
I'd go for the G35 purely for the fact that it has back seats. That alone can make a car impractical for some people. I also prefer the luxury that the G35 offers over the 350Z as well, and I prefer the styling overall as well.
Old Feb 28, 2005 | 02:15 PM
masetodd's Avatar
As much as I love my G35, the Z will always be considered more of a "sports car". If performance number bragging rights are your overriding purchase factor, then get the Z.
Otherwise, if you're deciding between the 2 cars, the seats are really the most important question - 2 seats? or 4? If you've never owned a 2-seater before, you're in for a suprise if this will be your only vehicle.
Old Feb 28, 2005 | 07:12 PM
da45king's Avatar
Bragging rights??They can only come with driving skill...I have yet to lose to a 350z and have left many scratching there head making excuses.
As for top speed the cars are governed at 155....beware not all 350Z have been able to reach this speed....A recent C&D tested one at 148....The was an owner on fresh alloy lamenting that his car could only do 140...U never know exactly what kind of tune your car has until U test it...(i.e. my rev limiter doesn't kick in until 6900 rpms.
* 6mts that have a rev limit of 6600 rpms would top out at 181mph...if the had enough power....the govner limits the car to 5500 rmps in 6th..156mph..if the car makes a max hp at 6200....the car should be good for atleast 165...if you had enough road...
Old Feb 28, 2005 | 07:17 PM
Z2G's Avatar
Z2G
the time that it took someone to post this and wait for replies, someone else could have done a simple internet search and would have gotten the answer within minutes/seconds. my goodness.......could someone tell me how many horsepower the coupe has too?!?!? : )~
by the way, i just typed "g35 coupe top speed" into the search bar on yahoo....and like magic, i found the answer within .1 seconds!!! wow, the magic of the internet: )
Old Feb 28, 2005 | 07:45 PM
JohnnyCham's Avatar
electronically limted to 155 i think.
Old Feb 28, 2005 | 07:51 PM
aren21's Avatar
Thanks for helping, I know I could have searched for it online, but I wanted an answer from a reliable source, I searched for it on this site but found nothing. Anyways, the G35 will be my everyday car, so the 4 seats are a plus. I know the 3 cars are pretty similar, but id rather go with the infiniti, cuz i like the looks much better than the Z.
Thanks for the info, and your opinions.
Old Feb 28, 2005 | 08:01 PM
G35Tuning's Avatar
Originally Posted by MrElussive
The 350Z is 200lbs lighter, has firmer springs, different exhaust tuning, and I believe a shorter wheelbase. All of these little differences make the 350Z a better-performing sports car but the question is, how much better?
I CAN tell you that when you drive the G35C hard, it is way sportier than its smooth apperance (inside and out) suggests. The car is very raw and tail-happy, there is a lot of power, and the handling is pretty well-balanced. If you need the back seats and trunk space, then go for the G. If not, go for the Z.
Shorter wheelbase has left the 350z with worse slalom times then the G35...Meaning our longer wheelbase has led to better performance times in handeling...Atleast I'm pretty sure..lol
Old Feb 28, 2005 | 10:52 PM
CKwik's Avatar
Originally Posted by G35Tuning
Shorter wheelbase has left the 350z with worse slalom times then the G35...Meaning our longer wheelbase has led to better performance times in handling...Atleast I'm pretty sure..lol
I think we will probably find that using the same tires, the Z would likely perform slightly better. The Pilot Sports are a better performing tire than the RE040s. The only place I think the G might better the Z is on the skidpad as the longer wheelbase would make it easier to keep the tail inline. Shorter wheelbases typically are better in slaloms as the front end can run a tighter line in relation to the rear. This tends to allow a slightly straighter line which means you can carry a higher speed.
rping
Jul 26, 2015 09:53 PM
multimut
Canada
Jul 26, 2015 08:43 PM
vstypicals
Jul 20, 2015 10:55 PM
nervseele
Jul 17, 2015 11:21 PM
driftsucky
Jul 15, 2015 12:38 PM
