Steering Shuddering
Old Feb 5, 2017 | 05:25 AM
Memz's Avatar
Question Steering Shuddering
Hi guys,
Just finished doing a re-shell from my old 03 G35 to a 04 G35.
Swapped Brembo Brakes/Rotors over as well (previous owner of 04 shell didnt sell shell with his brembos)
... Anyway, First time start up/turning the wheels while its on the ground rolling car around I can feel a violent shuddering come through the steering wheel during the turning action (power steering was freshly topped up) .. only happens when turning haven't gone for a long drive other than this small drive around due to not being currently on the road.
Anyone had similar issues?
Cheers in advance!
Old Feb 7, 2017 | 01:48 PM
gary c's Avatar
Getting that kind of reaction should only tell you something wasn't installed correctly or do the Brembo calipers clear the wheels on the new ride?
Gary
Old Feb 7, 2017 | 11:42 PM
Memz's Avatar
Same setup
Im running the exact same brake,wheel and suspension setup as old car.. odd thing is it isnt always happening.. but is noticeable when it does i was thinking maybe air in power steering lines or something will bleed and see how it goes
Old Feb 8, 2017 | 12:01 AM
gary c's Avatar
The "Violent Shudder" you describe has zero to do with your power steering! It's a rotational mismatch some where in the brake job you did! Recheck how you installed the rotors/claipers, proper torq and everything...Gary
Old Feb 8, 2017 | 11:12 AM
Urbanengineer's Avatar
It could be that, or the U joint from the steering column to the rack has gotten all frozen up. Spray some PB blaster or equivalent stuff on it and see if it solves your issue.
Old Feb 8, 2017 | 12:20 PM
gary c's Avatar
Logical I would have never thought of that, living in SoCal nothing ever freezes up or rusts...Gary
Old Feb 8, 2017 | 01:10 PM
Salt doesn't wear your stuff out there near the coast Gary?
Old Feb 8, 2017 | 01:32 PM
This is the part in question (above the blue seal), the U-Joint.Steering Shuddering-photo559.jpg
Old Feb 9, 2017 | 11:29 AM
LexD's Avatar
No. Most of CA uses sand and not salt on roadways.
Humidity is lower, essentially being a desert.
Also, the salinity of the pacific is less than the Atlantic waters.
Old Feb 12, 2017 | 09:43 AM
gary c's Avatar
Living 35 miles east of the Pacific Ocean we're not effected by salt air, since it almost never snows in SoCal salt isn't used on our roads! Liberal mentality is the main drag on our life style here on the left coast!
Gary
Old Feb 12, 2017 | 08:26 PM
Mr. Brooks's Avatar
This is the part in question (above the blue seal), the U-Joint.Attachment 177643
Make sure nothing is bent and everything is properly aligned.
Old Feb 12, 2017 | 08:52 PM
^Agreed! Thanks for the share guys.
