Replaced o rings on cam sensors now vdc light on
Old Dec 7, 2017 | 11:24 PM
phatrabbitzz's Avatar
Just replaced the o rings on, 06 G35 5at, both cam sensors and now I have slip, vdc light and service engine soon light on. I had no lights prior to replacing of the o rings.
Did I miss something? Just wanted to stop the oil leaks.
Old Dec 8, 2017 | 05:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
Dumb question but did you replace them in the right spots, passenger side is the straight one and the driver's side is the angled? I've never heard of someone replacing just the o-rings. How many miles are on your car, the sensors might just need to replaced completely.
Old Dec 8, 2017 | 10:15 AM
Yes as I replaced them one at a time. Car has 125k miles, odd that sensor would go bad the moment I take it out.
Old Dec 8, 2017 | 10:20 AM
Blue Dream's Avatar
It's odd yes, but over 100K it's not If they will fail but When. Get OEM when you replace them and they're a lot cheaper on Amazon than from a Nissan/Infiniti dealer.
Old Dec 8, 2017 | 12:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
OBD2 scan and find out what diagnostic trouble code it's shooting. Could be something simple like forgetting to plug something in.
Old Dec 8, 2017 | 09:07 PM
P0340 comes up, I'm guessing that's the passenger side. I took it out and made sure all was good and connected it back same thing happens... Debating weather to just order both sensors or just the passenger side and leave driver side alone.
Old Dec 8, 2017 | 11:17 PM
cleric670's Avatar
BANNED!!!
That's bank1 which is EDIT:passenger:EDIT side (determined by cylinder 1 from firing order), I would remove the harness and inspect it may just have wiggled something loose or damaged the harness/wiring in some way. Those pins can be bent "somewhat" easily.
Old Dec 8, 2017 | 11:20 PM
That's bank1 which is driver side (determined by cylinder 1 from firing order), I would remove the harness and inspect it may just have wiggled something loose or damaged the harness/wiring in some way. Those pins can be bent "somewhat" easily.
Are you sure? I'm looking at FSM and Bank 1 shows the one next to battery, passenger side.
Old Dec 8, 2017 | 11:48 PM
cleric670's Avatar
BANNED!!!
Yeah my bad, don't know wtf I was thinking there for a sec, cylinder 1 is the passenger front cylinder Sorry.
Old Dec 26, 2017 | 01:45 PM
Just wanted to follow up, turns out I bent one of the pins on the passenger side sensor when I initially put it in. Since the car has almost 130k on original sensor I went ahead and put in a new one and all is well.
Old Dec 26, 2017 | 02:25 PM
cleric670's Avatar
BANNED!!!
Awesome, glad it's working again.
Batfinity
22
Aug 12, 2022 12:18 PM
deathdoakill
Nov 29, 2015 03:20 AM
brenty_blanco
May 21, 2012 09:19 AM
Napoleon
Mar 22, 2006 08:31 PM
