NOT WORKING: Dome/Door Lights, Steering Column, Power Seats
Old Dec 13, 2017 | 01:11 PM
isaiahorop23's Avatar
hey im really new to the threads but i have an 06 g35 coupe with nav n bose and all that. Anyways, i put a new head unit in and everything was working fine. I went two weeks n it was okay then i removed the factory microphone (without unplugging) and put my kenwood mic in place of it. I put the cluster back in and the dome lights flickered then stopped working and the sunroof didn’t work. I then noticed it was the same harness for the sunroof and dome lights so i switched them and the sunroof works fine but no dome lights. Then i noticed my door step lights, steering column and seats do not have power to them however the passenger seat still reclines.
I tried checking fuses and nothing i could see but i also do not have a meter to check, i just eyeballed each fuse. I also tried disconnecting my battery for 20 minutes to reset the bcm and nothing.
Any tips help thanks!
*note: the ignition may or may not have been switched on. should have been more careful when installing i know. My concern isnt my stupidity, its how to fix my interior now lol
Old Dec 13, 2017 | 01:32 PM
jgonz951's Avatar
Try changing out the mirror fuse and check every other fuse. The G has 3 locations. One by the drivers side and 2 by the battery.
xplosive9z
Jan 31, 2020 10:50 PM
infinitig35_6mt
Jun 7, 2011 02:39 AM
xplosive9z
May 18, 2009 09:07 AM
slypr
Lighting
Feb 2, 2009 04:53 PM
