ABS,SLIP, VDC on, along with buzzing noise
Old Oct 22, 2021 | 12:42 PM
  #46
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Originally Posted by HeyZeus420
I had all of the aforementioned problems, And using the percussive maintenance method worked perfectly the lights remained on until I drove it about 10 ft and they went off... I will start looking for a new relay but it's good to find answers that keep you on the road until it arrives thank you so much!
Unplug the harnesses and take a picture of the relay plug without the harnesses, then go to your local pick-and-pull scrapyards and find basically ANY Nissan/Infiniti from 2000-2015ish and it should have a compatible relay. They're crazy expensive to buy new for some reason. It might not have the exact same bracket so you might need to attach it to the fender with some 3M double adhesive tape.
spechops
Feb 5, 2011 11:06 AM
IPSECG35
Dec 6, 2007 11:45 AM
Igor911
Feb 14, 2007 01:20 AM
Kyosho
Feb 4, 2005 02:00 AM
