What Causes The RPM's To Get Stuck?
Old Apr 23, 2018 | 08:17 PM
AnonG35's Avatar
Question What Causes The RPM's To Get Stuck?
The REV light was adjusted to 4600 on this, but the needle wont go past 4K
Old Apr 24, 2018 | 07:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd say your tach is fried, obviously it's not showing the correct values and that huge stutter it makes midway through usually means the stepper motor is going out. HOWEVER you can verify to make sure it's not a bad signal being sent to it by using an OBD2 scanner and reading the tach values from there, if it shows the same values as displayed on the tach then you have some kind of issue with the signal sent from the ECU.
It's also possible you have a ground issue with the combination meter but that would usually affect EVERY gauge not just one.
Old Apr 24, 2018 | 08:04 PM
AnonG35's Avatar
Thanks for the reply. I’ll take a look at the tach through the OBD reader. Didn’t know that was possible. Also, can the stepper motor be repaired or replaced?
Old Apr 24, 2018 | 08:24 PM
cleric670's Avatar
BANNED!!!
They can but I have no idea how you would go about doing that on this cluster. Anything can be replaced if you have the necessary skills
Old Apr 26, 2018 | 05:24 PM
raygun's Avatar
There's a gauge cluster diagnostic routine detailed in the service manual that'll let you move all the gauges, test the lights, etc. It's intended for exactly this kind of thing. It might shed some light on this.
Old Apr 26, 2018 | 07:30 PM
cleric670's Avatar
BANNED!!!
The problem with the diagnostic mode iirc is the gauges only go up like 25% when you press the trip odometer button. I can look for the instructions on it later when I'm home but I think you just hold the odometer button down and turn the ignition to ON then press the odometer button 3 times. Then every time you press the button again it makes the gauges move.
nrg1
Jun 6, 2016 10:10 AM
SFGIANTS916
Mar 3, 2016 11:33 AM
Maciuniu
Jun 5, 2011 10:10 AM
k_lundquist
V36 General Tech Questions
Aug 29, 2008 09:39 PM
Wanchu83
Jan 12, 2006 04:46 PM
