NEED HELP . Engine light on
Old Oct 14, 2018 | 12:05 PM
John101300's Avatar
Black g35 coupe all stock with straight pipe
So i recently had to change all my spark plugs and my cylinder 5 coil cause i was misfiring . That problem is fixed and out the way. But now i have a code that says “ idle air comtrol valve “ for some reason i cant find anything with the location of that part. Can this simply just be a vacuum leak somewhere or a damaged throttle body?
Old Oct 14, 2018 | 12:31 PM
FreshLikeAG's Avatar
I'm almost certain there is no idle air control valve. That would be the job of the throttle body. Are you sure you plugged the tb and the maf sensor back in? Hopefully you didn't play with the valve on the throttle body as that's known to cause problems. If you trace back through everything you disconnected and seems ok, then you can try the idle air relearn procedure.
Old Oct 14, 2018 | 12:35 PM
John101300's Avatar
Everything seems to be plugged in right we did go back and look at everything once more . . When cleaning the throttle your not supposed to open the butterfly at all? If not then that must be the problem cause we did clean all of it . But still very gently . Also everything feels normal on the car my drive feels good and i have a good idle .
Old Oct 14, 2018 | 01:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What code are you getting, there is no code for the idle air control valve because this vehicle does not have one.
Mark7
Dec 21, 2019 06:22 PM
bendigi
Mar 20, 2015 12:44 AM
Reckless_405
Jan 28, 2015 06:39 AM
