German Castrol oil
German Castrol oil
So it’s now 2018 and I just now bought a g35 and I’ve been searching which is the best oil for my 06 g35 coupe 6mt revup. German Castrol seems to be the one to go with but do they still make it?
The newest post I saw was from 2012. To my understanding German Castrol is just 0w-30 Castrol that says made in Germany in back correct?
I was thinking it would be in a green bottles but when I look I don’t see anything online. I’ve only been able to find one 0w-30 Castrol oil it’s in a black bottle and on the front says “European Formula” is this the real deal or is there some other oil I should use?
My car has 104k miles on it i bought it with 103k miles. In about 900ish miles it has used a 1/4 quart of oil (1/4 down on the dipstick)
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
Hi. People can debate oil all day long but imo there isn't much of a difference. Somewhere out there exists a Blackstone chart showing the best oils for wear but honestly just use any 5w-30, a good filter and just change it often.
You own a 12 year old sports car, you've a bit got more to worry about than what oil brand you put into it
also, welcome.
also, welcome.
Bearing tolerances require specific oil viscosity, unless you have rebuilt your engine to tighter tolerances then stick with the proper viscosity. Don't believe all the hype you hear from people who don't have any scientific data to back their claim.
The blackstone thread was something like 30 cars using various different oils, the spreadsheet was completely useless because you have no idea what condition the motor was in or how the vehicle was driven and the sample size literally had 1-2 engine comparisons on the same oil. It was a nice attempt but there was a total lack of data to build any kind of definitive answer with. I guarantee Nissan however has done the math and engineered the best viscosity of oil for their motor. I believe it's just 5w-30 winter and 10w-30 in a hot summer environment. Track use is different and you might bump up to 10w-40.
If you want to know how YOUR EXACT ENGINE is behaving with any specific oil then get your own blackstone test done and look at the report.
also, welcome.
also, welcome.Bearing tolerances require specific oil viscosity, unless you have rebuilt your engine to tighter tolerances then stick with the proper viscosity. Don't believe all the hype you hear from people who don't have any scientific data to back their claim.
Engineered based on conventional but as long as you aren't consuming and excessive amount of oil there's no harm running synthetic for the longer oil change interval. If you start to consume more oil using my thetic then just switch back to conventional on the next oil change.
buzzking
Engine - Intake/Fuel
Jan 12, 2013 12:24 PM
eljoker
26
Dec 14, 2012 07:45 PM
danielw
24
Dec 21, 2010 08:35 PM
lekker_droom
14
Sep 11, 2008 11:25 PM
