2006 G35X Pass side CV Axle won't come out.Help!
I read the DIY on this job but the inner spline will not come out. I've pried and pulled and tried to turn for an hour. It has about a 1/16th of an inch play that it will allow you to pull then stops. The rest of the shaft is out and just the boot and the spline in the differential remains. Getting close to having it towed to a shop. 17 year old daughter's car and I'm under the gun!
Buy her a new car.
A stick shift Honda Civic.
None of her friends will ever ask to borrow it because most can't drive a stick
Telcoman
Telcoman
My neighbor,who has owned a Diesel shop for 25 years is stopping by within the hour. He said he's never had to use anything but screwdrivers and prybars. We'll see if he's still saying that with this setup on jackstands.
Yeah I've taken out MANY CV axles the wrong way with a small prybar that has dimensions similar to that screwdriver until one time I accidently cracked a transaxle doing that. There's a reason the FSM, every Haynes/Chiltons manual and every other shop manual ALL say to use a slide hammer, it's basically just common knowledge by now. It's the right tool for the job with no inherent risk of damaging the housing of the axle.
Yeah I used to just wedge the prybar against the side of the first joint and give it a quick shove as well lol. I probably did that for 15 years before I ever had the problem with that transaxle on an early 90's Sentra. There isn't a LOT of pressure on that internal snap ring and it was probably simply due to the design of the transaxle but I'll never do it again like that.
munkle
Oct 11, 2013 09:39 AM
ARB_MNY_G35x
Feb 4, 2013 06:47 PM
