Tips and Tricks
Old Mar 6, 2005 | 10:19 PM
jwarner's Avatar
Thumbs up Tips and Tricks
Okay, so I just learned that if you press and hold the steering wheel audio control to advance the track on a CD, it will advance to the entire next CD (as opposed to pressing it briefly, which will advance the track on the current CD).
So it made me wonder if there are other little tips or tricks I don't know about my new 05 6MT Coupe?
And a question - Can I disable the horn beep when I arm the alarm? (I'd probably rather just have the lights flash)
Jason
Snohomish, WA
05 6MT Diamond Graphite
Old Mar 6, 2005 | 10:32 PM
Jp1's Avatar
Jp1
Check your manual. There's two ways to lock the car. One has the horn/flash and the other has the signals flash twice with no horn.
Old Mar 6, 2005 | 10:40 PM
GRider35c's Avatar
do u know u have a shift light?? ; )
Old Mar 6, 2005 | 11:18 PM
EricIsKlumzyee's Avatar
when your head unit shows a title and its cut off you can tap "Display" button and it'll scroll.. didnt figure that out til a few days ago
Old Mar 6, 2005 | 11:21 PM
G35miked's Avatar
did not know about the window thing, thanks a lot.
Old Mar 6, 2005 | 11:22 PM
G35miked's Avatar
hate to sound stupid, but do we really?
Old Mar 6, 2005 | 11:26 PM
hensta's Avatar
...only on the '05, and only if it's a 6MT
Old Mar 6, 2005 | 11:27 PM
Pwoz's Avatar
If you hold the key in the door and turn it will roll the windows up.
Hold lock and unlock on the key for (I think) 5 seconds and it will turn the horn off when you lock.
Old Mar 6, 2005 | 11:29 PM
the 2005s and up have one, duno about 03, 04.. but to set it you push you put the trip button to the 3rd setting, it should say "7,000" for stock..
1. hold down trip reset
2. set the number by pushing trip reset
3. when your done.. leave it for about 15seconds and it'll go back to normal
the rev light starts blinking about 500RPMs before you hit your mark and when you hit your mark it'll be come solid.
also if you stick your key into the driver door and turn it left and hold it there you can roll up your windows too..
kinda useful when my passenger forgets to roll up the window
edit: u guys beat me to it
Old Mar 6, 2005 | 11:30 PM
G35miked's Avatar
o ok thanks for the info on the shifter light.
Old Mar 6, 2005 | 11:36 PM
question: lets say i have 80songs in one directory... what is the quickest way to get to song #40?
also can the seats in the back be adjusted? lol owners manual is in my car thats in my car cover
Old Mar 6, 2005 | 11:39 PM
hensta's Avatar
On all '05 models with Bose, if you want to have the Bass or Treble higher than "0" you'll have to adjust it every time you turn on the car. That's right. The bass and treble sound levels always default back to "0" when you turn off the car. EVEN IF when you restart the car and you have it set on, for example, 3 for Bass and 3 for Treble you'll have to adjust it one down then back up to have the stereo adjust it to the desired level, 3 in this case. Upon starting the car it may DISPLAY 3 for Bass and Treble but it will not SOUND like the 3 level settings until you readjust it every time. There is a whole thread on this in the audio section. So far there has been no fix for this and I do not wish to rehash/hijack this thread with the details. It will be a few more weeks/months before Infiniti has a fix for it-they have to acknowledge that it is a bug in the Bose programming first.
Old Mar 6, 2005 | 11:43 PM
never noticed that.. lol i'll check that out tomorrow, thx for the heads up
Old Mar 6, 2005 | 11:57 PM
gnut's Avatar
Hey, my treble and bass do not reset back to zero after I turn the engine off. Did they fix the problem already? Or do you mean to turn the radio instead of the engine off?
