so I got into a front end collision I hit a suburban
I just replaced the core support last night and bought new aftermarket headlights the sequential ones so I can still drive the car but I still need a fender so if any of you guys know where I can find a fender or are selling one that would be great and preferably in red
This also broke and I can’t figure what it’s called,I’m also missing the bolt that connects the core support to the fender and the frame so if you could tell me where I can find that that would be great
Z1 price is not bad; $3+ cheaper than Infinitipartsdeal.com (retail is $19.17, they have it at $14.09. Z1 is $10.70. As always, check shipping costs....
Check out section EI Exterior & Interior, it covers a lot of the fasteners (with part numbers) that you will need as well as torque values.
CO Cooling for stuff pertaining to the radiator.
FSU Front Suspension
For anything else the FSM starts with the FWD Forward document.
That's the listing of how many lbs of torque it takes, it's listed in the 3 global torque standards and you will likely want to use the ft/lbs one which is 14-17 ft/lbs according to the FSM.
These are the exact same exploded view diagrams that the dealership parts counter has so you might be able to just get that bolt from the dealership. Personally though I would try to find a local pick-n-pull that has a G35 or 350Z on hand so you can just rob bolts from it instead.
