Hi guys, recently I posted topic about problem I had on my g35;
Well there is another issue now. Passenger headlight doesn't work, so I got a bulb, replaced and boom still doesn't work. I went to purchasing ballast and at some point before I didn't get ballast it start works again and again stop. I still didn't replace ballast because I were waiting for my friend to help me out but I m gonna probably do that by myself bc I wanna save some money. Mechanic asking for 120 only labor (LoL).
My question is, what I should test before I did change ballast because it could be maybe wire problem and should I remove bumper to do change or only that plastic under the headlight and then I 'll be able to replace it.
Thanks guys,
Thanks guys,
Scorpi0
close
- Join DateFeb 2018
- LocationLA, Cali
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:445 Times in 394 Posts
Sounds like a ballast problem. U will have to remove the headlight in order to change the ballast.
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
Swap the ballast and lamp that are working to the side that's not working. Then you can verify it's a wiring/electrical problem
Quote:
Same thing is occurring to me with my driver side headlight. Replaced the headlight, bulb, ballast & even tested the ballast on the passenger side and it worked. Thinking it’s a short to ground. Originally Posted by cleric670@gmail
After over 2 months replaced ballast. In order to replaced i remove wheel, then that plastic and it was really hard to reach old ballast. 2 screws were removed easily but 3rd one had to break. Cable on a new ballast was to short so i has to use old cable for bulb.
Headlight is working now but i got check engine light...
cleric670
BANNED!!!
close
- Join DateMay 2017
OBD2 scan for codes, probably unrelated to the ballast.
Quote:
P1065, related to ECU but didn't have that before i changed ballast. Originally Posted by cleric670@gmail
I will try just with reset and see what's gonna happen.
cleric670
BANNED!!!
close
- Join DateMay 2017
By chance did you do this work with the battery still connected? If so you should start checking every single fuse starting at the fusible link because something probably blew.
Quote:
Battery was disconnected. I will check it, thanksOriginally Posted by cleric670@gmail
cleric670
BANNED!!!
close
- Join DateMay 2017
Have you tried deleting the code to see if it comes back?
Quote:
On sunday, i was trying to fix air bag light what is also common isue on g35 because they have recalls on connectors under passenger seats. At that time battery was disconnected so check engine code dissapear. But air bag light is still there. I follow instructions from youtube with disconecting and conecting few times and using dielectric grease but air bag light come back. Also after i cut zip tie on that connector i couldnt connect plug in that there again so i had to use zip ties again. Those connectors are really shame for infiniti...Originally Posted by cleric670@gmail
