crank sensor question
Old May 31, 2019 | 06:12 AM
ashleytea666's Avatar
6spd MT, coupe, stock
um, so this might be a stupid question but is the RPM gauge supposed to show anything while its cranking? The car doesn't start so i'm not sure if i should be wary of that or what. Would a bad crank sensor cause a "crank / no start issue"?
Old May 31, 2019 | 03:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Crank no start with nothing shown on the tach while cranking is usually a failed crank sensor. Replace with a genuine Nissan or Hitachi sensor.
Old Jun 1, 2019 | 03:11 AM
i forgot to mention that its not throwing any codes... is that important? or would a failed crankshaft sensor be where i should focus
Old Jun 1, 2019 | 03:22 AM
so i found a hitachi crank sensor but i see two different hitachi crank sensors ?? theres a silver roundish one, and then the black plastic-y looking one. how do i know which one i need?
Old Jun 1, 2019 | 05:19 AM
Scorpi0's Avatar
Silver roundish one is the newest version of the sensor. Supposed to last way longer than the plastic one. It will cost a bit more too.
Old Jun 1, 2019 | 07:06 AM
[QUOTE=Scorpi0;7169254]Silver roundish one is the newest version of the sensor. Supposed to last way longer than the plastic one. It will cost a bit more too.[/QUOTE
Actually I think that one was cheaper by a few dollars....
Old Jun 1, 2019 | 10:35 AM
Scorpi0's Avatar
Its usually the other way around but hey...sometimes miracles do happen!!
Just make sure it is indeed an OEM sensor.
jberd45
Jul 13, 2016 06:43 PM
ScraggleRock
May 3, 2015 06:22 PM
ImPoppi
Jul 24, 2012 10:58 PM
Skaterbasist
12
May 2, 2007 10:27 PM
djniknala
May 11, 2005 03:45 PM
