VDC off and SLIP light stays on!
I know this question has been beaten to death. I have owned my 2005 g coupe for 2 years and have had the issue since I assumed it was brakes because they have needed to be done for a long time. But today I replaced my rotors and brake pads all the way around and my brake fluid is at a good level. Also had tires replaced yesterday and still get a random tire pressure light once and a while. Both turn off when car is restarted. Also I have replaced my right bank cam sensor I believe because of service engine soon light, which I know I’ve seen around so that’s also not the issue. Could it be a speed sensor?? I need some ideas
My only issue is if I take it in and they tell me there is t anything wrong because it’s a soft code.
That's not how it works, they'll plug in Consult-II and run the diagnostic and tell you exactly what's causing the lights to turn on. Unfortunately it's just a lot of guesswork without the Consult-II software.
I have an OBD 2 reader and the issue is it’s a soft code so when I turn the car off then on it’s gone and doesn’t get picked up.
Mark7
Dec 21, 2019 06:22 PM
Reckless_405
Jan 28, 2015 06:39 AM
VQPWNAGE03
Aug 31, 2007 02:19 AM
