Window Help
Old Jul 11, 2019 | 03:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Except me just put a new motor on it and it's still having the same issue.
Use a digital multimeter and measure voltage at the 2 pin harness on the motor, should he 12v up and -12v down.
Old Jul 11, 2019 | 05:51 PM
Scorpi0's Avatar
Thats why I recommended jumping the motor directly to battery. Takes all the guessing out of having a weak link somewhere in the circuit.
Old Jul 14, 2019 | 04:58 AM
AwayV2's Avatar
G35 Coupe
how do you link it straight to the motor
Old Jul 14, 2019 | 05:29 AM
Scorpi0's Avatar
With some long electrical wire
Old Jul 14, 2019 | 03:06 PM
cleric670's Avatar
BANNED!!!
Yep, long leads with aligator clips on both ends and an inline fuse holder on the positive side. Toss in a 10A fuse.
I prefer the insulated gator clips when doing little probes on harnesses like that. If you don't have insulated ones you can "make them" by wrapping them lightly with electrical tape, just don't put it on too tight, you still need to be able to open the teeth.
Old Jul 14, 2019 | 03:07 PM
cleric670's Avatar
BANNED!!!
I also strongly recommend disconnecting the battery completely when doing stuff like that, all it takes is one little arc to fry all sorts of sensitive computer stuff on your car.
Old Jul 23, 2019 | 07:08 PM
AwayV2's Avatar
G35 Coupe
it was my battery, once it finally died and i replaced it the original motor that i thought burned out started working and the window moves freely up and down now unfortunately the battery i had and motors i bought were the culprit
Old Jul 25, 2019 | 01:51 AM
AwayV2's Avatar
G35 Coupe
problem is still happening on driver side but passenger side is only coming up half way i’m ready to just give up and sell the car thanks anysways everyone
Old Jul 25, 2019 | 04:21 AM
Scorpi0's Avatar
Dont be a quitter man! Have a few beers and get back at it
CalsonicVQ
Mar 14, 2007 01:28 PM
klwoods
Nov 19, 2005 02:04 PM
Fghtr112
Oct 15, 2003 07:22 PM
