ECU doesnt power obd2 scanner
Old Aug 17, 2019 | 06:52 PM
JvillelaVQ35's Avatar
2006 g35 coupe
Ive been having a problem with My 2006 g35 for about 1 month that when I start it up idk I can hear the exhaust sound is not the same as it was before, the car start up fine but when I start driving shortly the SES light comes on and my rpms and speed climb up slowly when I press the pedal. It's like something is putting my car in limp mode. I tried checking the code but the scanner will get no power from the car. I checked out where the obd2 port is at and you can see a connection is not connected I have no clue where it goes my car was running perfectly 2 months ago.
Old Aug 17, 2019 | 10:48 PM
G2B35AGN's Avatar
I would suggest you Service Engine Soon.
Old Aug 19, 2019 | 06:06 PM
Galo's Avatar
'06 AX6 G35 Coupe 6sp RevUp 19" Rays RAS, Solar Yellow '01 MR2 Spyder w 2ZZ/C60
OP, you should get your car to the dealer or a highly respected independent tech, and have it checked out...very soon.
Crappyday
Mar 15, 2022 07:17 PM
tylerxfire
May 16, 2012 10:43 AM
Parasite.13
Jul 18, 2010 10:17 PM
blueG1
May 10, 2008 03:10 AM
