Car Staring issue. 2005 G35 Coupe MAT
Old Oct 27, 2019 | 07:45 AM
KDomfeh23's Avatar
2005 Infiniti G35..just now looking into mods
Every time I try to start the car it makes a click sound and shuts off. I changed my battery thinking that was the problem but it kept on going. What do I do?
Old Oct 27, 2019 | 08:50 AM
Mr.GEE's Avatar
20 Year Member
Check battery cables for corrosion on both ends, especially the negative cable connection to the engine and body. If all is good, then you may have a bad starter motor.
Old Oct 27, 2019 | 08:52 AM
telcoman's Avatar
Veteran: Army
http://www.nicoclub.com/FSM/G35/Coupe/2005/sc.pdf
See page SC 10
STARTING SYSTEMPFP:23300System Description AKS003Z1M/T MODELPower is supplied at all timesthrough 40A fusible link (letter M, located in the fuse and fusible link block)to ignition switch terminal 1,through 10A fuse (No. 71, located in the IPDM E/R)to CPU of IPDM E/R,through 15A fuse (No. 78, located in the IPDM E/R)to CPU of IPDM E/R.With the ignition switch in the ON or START position, power is suppliedfrom ignition relay (located in the IPDM E/R)to 10A fuse (No. 89, located in the IPDM E/R)through IPDM E/R terminal 25to clutch interlock switch terminal 1.When the clutch pedal is depressed, power is suppliedthrough clutch interlock switch terminal 2to IPDM E/R terminal 53.Ground is suppliedto IPDM E/R terminals 38, 50 and 60from grounds E17 and E43.Then starter relay is turn ON.With the ignition switch in the START position, IPDM E/R is energized and power is suppliedfrom ignition switch terminal 5to IPDM E/R terminal 4 andthrough IPDM E/R terminal 3to starter motor terminal 1.The starter motor plunger closes and provides a closed circuit between the battery and starter motor. Thestarter motor is grounded to the engine block. With power and ground supplied, cranking occurs and theengine starts.
Did your IPDM ever get wet?
Old Oct 27, 2019 | 11:59 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does it make a really LOUD click like from the starter or is it a very quiet click like from a relay?
The starter click is more of a loud THUNK as the gear engages the flywheel.
Old Oct 27, 2019 | 12:27 PM
KDomfeh23's Avatar
It’s a quiet click
QuesowithPesos
Feb 26, 2020 09:39 PM
Quann J
Aug 19, 2019 06:03 PM
shkeller55
Jul 20, 2016 11:25 AM
G35Woody
Jul 9, 2016 08:44 AM
zcherub
Aug 27, 2015 09:47 AM
