Tailight Fuse Keeps Blowing
Old Nov 12, 2019 | 11:17 PM
SLW_G35's Avatar
Auto Coupe
I have an ‘05 G35 Coupe. My tailight fuse keeps blowing and when it goes the climate control lights, light for the gear selector, and the clock on the dash all go out; the dimmer switch doesn’t work either. Anyone else have a problem like this and have a fix for it?
Old Nov 13, 2019 | 07:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Something is drawing more current than it should, might also be a broken wire in the trunk flexible loom that is shorting out.
Old Nov 14, 2019 | 01:50 PM
telcoman's Avatar
Veteran: Army
Have you followed the troubleshooting steps in the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2005/lt.pdf
Turn ignition switch OFF.2. Disconnect BCM connector.3. Check voltage between BCM harness connector and ground.
Check harness for open or short between BCM and fuse.
Zepster
Jul 1, 2019 10:37 PM
snunez
Oct 27, 2018 03:29 PM
Idris Yusuf
Jan 9, 2017 06:52 PM
Markos2005
Jan 21, 2014 09:05 PM
