Missing hose.
Old Jan 18, 2020 | 02:00 PM
Lil_Spanish's Avatar
I have a 2005 g35 coupe automatic tranny
Missing hose.
Ok so I was changing valves and I can't seem to find a hose that connects to that part. What is it? Or does it connect to the plenum? Cause I believe there was a hose I disconnected and left on plenum. And also there's a hose on top of my manual trans that seems to be connected to anything. I don't remember touching it at all but I found it and it wasn't connected to anythin. What is it?
Old Jan 18, 2020 | 05:34 PM
shurur's Avatar
2003 G35 Coupe
I think that is the purge line that goes to your intake/thottle body.
The hose for that may be still on your intake..you should at least find a nipple for that hose around the TB.
I think it feeds or purges fumes from the gas tank into the intake at WOT.
There is another switch like that back by the gas tank near the fill neck that normally vents (evap) the fumes out of the tank into the air..at WOT the rear switch redirects fumes to purge to the front via hose while the front opens and allows feed to the TB.
Also maybe your TB hose nipple may have been blocked off by someone...so look for that.
Old Jan 19, 2020 | 06:06 AM
Scorpi0's Avatar
Where da hose at?
Old Jan 19, 2020 | 07:58 AM
shurur's Avatar
2003 G35 Coupe
Originally Posted by Scorpi0
Where da hose at?
163 likes on 155 posts....
blkdout04
Intake & Exhaust
Nov 2, 2012 08:50 PM
saywat?
Apr 3, 2012 07:13 PM
stanjansen
Sep 6, 2011 05:21 AM
FLFIRE
Mar 20, 2005 02:00 AM
