Coolant hose
Old Jan 18, 2020 | 08:35 PM
Lil_Spanish's Avatar
I have a 2005 g35 coupe automatic tranny
Coolant hose
Ok so while doing a valve cover replacement, I tried to get that hose loose so i can get more clearance to one of the bolts on the cover and I even loosened up the clamp. And at the end I forgot to tighten up the clamp and when I was done I turned on the car and it leaked bad. But now I tried pushing the hose down and tightened down the clamp but it doesn't tighten all the way just to a certain limit and it just gets loose till it reaches the limit and gets loose again. And when I try to tighten the clamp right before it gets to its limit it still leaks a little. Whats that hose called? And what kind I do to get it to stop leakin? Should I get another clamp? I tried looking to see if I ripped the hose but I didn't see any cracks or tears.
Old Jan 19, 2020 | 03:19 AM
shurur's Avatar
2003 G35 Coupe
The passenger side 3/4" ID hose is the heater hose..the smaller one behind it (more toward the firewall) is the throttle body coolant hose. The arrangement us the opposite order on the driver side.
The worm gear hose clamps can get the slots pulled or stripped so that they will not tighten.
You should get a new one. You can get one at any HW store.
A better clamp is an oetiker clamp that is crimped on or maybe even a pex pipe clamp, but I am not sure what sizes the pex come in.
It may be too dificult to get the crimp tool in there to crimp a oetiker anyway...but definitely get a new worm gear hose clamp and don't overtighten and strip it.
If you can get or find a proper size spring clamp at a auto store, that is probably best, but I never have much luck finding those locally even at auto parts stores. That is what was on the hose originally OEM.
Old Jan 19, 2020 | 05:32 AM
Thanks for the info. But it will leak if I try to change the clamp correct? Like it will leak a lot once I remove the hose from where it's connected. Any ideas on how to keep leakage at a minimal or how to remove it if it's on there really tight?
Old Jan 19, 2020 | 07:54 AM
shurur's Avatar
2003 G35 Coupe
you can loosen the old worm gear clamp completely and remove it, then put a similar clamp back on.
Old Jan 19, 2020 | 12:06 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I usually torque those little 1/4" worm drive clamps like the one in the picture to 30 in/lbs and I've never had an issue with them backing off. The bigger 5/16" ones I usually use 50 in/lbs.
Old Jan 19, 2020 | 06:32 PM
Scorpi0's Avatar
Why was my super informative post removed??
Old Jan 19, 2020 | 07:48 PM
cleric670's Avatar
BANNED!!!
What post? What did it say?
EDIT: Wrong thread @Scorpi0 you're looking for this one.
https://g35driver.com/forums/g35-cou...sing-hose.html
Old Jan 19, 2020 | 11:32 PM
Scorpi0's Avatar
Oh crap youre right! That really threw me off. Thanks Cleric. I feel way better now
Harve
Mar 18, 2019 10:16 PM
Salim Amrani
Nov 18, 2017 07:41 PM
Cernad
May 29, 2017 06:50 AM
sabino787
Feb 22, 2014 08:12 PM
stanjansen
Sep 6, 2011 05:21 AM
