Lights on the dash and a/c & heat not working
Old Feb 15, 2020 | 12:46 AM
KDomfeh23's Avatar
2005 Infiniti G35..just now looking into mods
Two questions..
1. What does it mean if all the lights on my dash are on lights I mean brake, vdc, etc?
2. My a/c & heat don’t work. I don’t hear a sound when trying to turn it on
Old Feb 15, 2020 | 03:00 AM
Scorpi0's Avatar
Is the check engine light on? If so, scan it for codes.
Old Feb 15, 2020 | 08:34 AM
KDomfeh23's Avatar
Check engine light not on
Old Feb 15, 2020 | 10:51 AM
Scorpi0's Avatar
Cool. See this thread: https://g35driver.com/forums/g35-sed...dash-help.html
Old Feb 15, 2020 | 11:04 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check cabin Fuse Block - J/B fuse 19 should have full time power, fuses 6 and 14 should have power with the ignition ON. All are 10 amp fuses, probe the tops of them for voltage with a DMM.
Also check the fusible link holder slot D, 60 amp main fuse, there are no probe points on it so just pull the fuse and verify it has continuity with a DMM.
Obviously you should disconnect the battery if you are pulling fuses.
Old Mar 29, 2020 | 09:07 PM
KDomfeh23's Avatar
Lights have been fixed but a/c & heat still not blowing
Old Mar 29, 2020 | 09:18 PM
cleric670's Avatar
BANNED!!!
Replied to the other thread you posted.
SLW_G35
Oct 17, 2019 12:56 PM
