best place for door actuator kits
Hi I want to fix my sons G35 coupe door locks and my other sons FX door locks but tried for a month or so to get in touch with usactuators and they will not respond to phone calls or emails so guess they are out of business. Has anybody used another good source? I need to fix the tailgate on the FX as well as doors.
Things like that I typically just buy used on eBay.
Are you sure it's the actuator and not a wiring/BCM issue? Have you tested for voltage at the actuator harness? It's not a common part to fail and for both doors to fail on the same car sounds more like an electrical problem. Wires are commonly known to break in the flexible wireway between the door and the cabin on these platforms so I would definitely test out the circuit first for intact wiring as well as watch the BCM send signal to lock/unlock at the actuator harness.
canehdian_guy
Jun 10, 2017 12:07 PM
