Clutch & Flywheel replacement
Old Apr 1, 2020 | 02:28 AM
JorgeDamien's Avatar
g35
So I just bought a 2003 6MT sedan and it has 165k on the stock clutch and flywheel! I bought it off the original owner and he said he never replaced it. That being said I am definitely going to do a replacement because in just the few day's I've had it I've driven it harder than it probably ever has been.<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->omegle discord xender
I can't decided whether to do an OEM spec or stage 1 clutch, either with a DMF or SMF. I've seen videos (I'll link one on YouTube below) of the chatter caused by SMFs and I'm not sure if I want it to make that much noise. And since I'm daily driving should I bother to do stage 1?
Old Apr 1, 2020 | 12:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you want to keep the luxury car feel get a DMFW with the stock clutch friction. A lightweight flywheel will be noisy but is a pretty substantial performance improvement, stage 1 clutch if you plan on doing bolt on stuff like spacer+hfc+exhaust+tune. If you're not going to mod the car just stick with the OEM setup because it quickly loses the luxury car feel and goes straight to sports car.
Old Apr 1, 2020 | 12:46 PM
cleric670's Avatar
BANNED!!!
OEM rebuild kits for the CMC/CSC are under $50 for the pair, I recommend going that route rather than buying non-oem replacements.
smash
Drivetrain
Dec 12, 2016 10:59 PM
mercertj
Drivetrain
13
Apr 20, 2011 03:06 PM
larry6
Feb 4, 2006 03:25 PM
