Suspension question
Old Jul 24, 2020 | 12:45 PM
ashleytea666's Avatar
6spd MT, coupe, stock
Suspension question
Can I use the suspension from an 05 automatic coupe in an 06 MT coupe? I'm talking the whole suspension: struts, compression rods, all the links and all that stuff. Will it mess anything up if I do? I read something about stiffer springs on the sport suspension, if I had the struts and springs for the sport would I be able to use the rest of the parts of the 05 suspension?
Old Jul 24, 2020 | 01:51 PM
cuzin.danny's Avatar
INFINITI G35 Coupe 6MT w/Brembo's
Suspension parts are all the same through 2003-2006, unless you have a coupe with RWAS (rear wheel active steering) or if it's a G35x (All-wheel drive). Only difference with those struts is that they'll be a little bit stiffer than usual. If you're installing the parts yourself you shouldn't mess anything up as long as you follow the FSM on nicoclub's website.
Old Jul 24, 2020 | 01:53 PM
Perfect. Thanks!
Old Jul 28, 2020 | 12:37 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Only thing to be mindful of is that G35's can have different spring rates and dampers based on whether it has the sport package or not.
Old Jul 30, 2020 | 04:34 PM
Ok so I changed the whole front suspension (the axel, the links, ball joints and pretty much everything else except the sway bar and the steering rack or whatever it's called. But now when I try to drive the car won't accelerate and the slip light comes on when I push the gas pedal .. wtf did I do?!
Old Jul 30, 2020 | 06:01 PM
Make sure you didn't pinch any of the wheel speed sensors/abs wires near the backside of the wheel hub. Double check all the connections you may have unplugged and make sure nothing is loose.
You also mentioned front axle. Are you working on an All-wheel drive model?
Old Aug 2, 2020 | 03:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pretty sure you have a front wheel speed sensor not plugged in or maybe bent a pin. Also possible that one of them is bad if you used the donor vehicle wheel speed sensors.
hoon
Oct 28, 2017 10:08 PM
mza4
Aug 23, 2006 10:09 PM
mikeinaustin
Apr 29, 2005 07:05 PM
paolo
Mar 1, 2005 10:25 PM
