Car smoking and leaking
Old Aug 20, 2020 | 10:57 PM
roody's Avatar
I was driving earlier today and my car started getting white smoke coming through the hood, so I pull over and check it out. I checked under the car and the leak is near the middle of the car. I also found that this axle on the drivers side was greasy, but on the passenger side it is clean. Any help? I just want to know whats wrong. Update: I'm pretty sure it is oil, but I still don't know why it was smoking.
Old Aug 20, 2020 | 11:01 PM
roody's Avatar
I also have no exhaust. I only have the cats and Y pipe on the car.
Old Aug 20, 2020 | 11:39 PM
Scorpi0's Avatar
Well....what fluid is it leaking? Get in there with a flashlight and see where its coming from.
Old Aug 21, 2020 | 12:02 AM
roody's Avatar
I think it is oil.
Old Aug 21, 2020 | 02:24 AM
Scorpi0's Avatar
Originally Posted by roody
I think it is oil.
Go check it out.
Old Aug 22, 2020 | 12:13 PM
LI-G35Driver's Avatar
Are your valve covers leaking? Did you spill any oil when you last added/ changed oil? That plastic engine cover and gasket around the oil filler cap do not necessarily catch oil when adding, you do need a funnel if pouring from a 5 qt jug.
Old Aug 22, 2020 | 03:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you're leaking oil, fix it, problem goes away.
I don't know what else to tell you man.
Terry_G35
Jan 29, 2016 11:44 AM
JDMPenn
Nov 18, 2011 02:47 AM
riflydon
Nov 15, 2009 10:24 PM
pkelly0120
Apr 5, 2009 07:05 PM
dopey
Jun 19, 2007 12:02 PM
