Brake fluid recommendation for 2005 6MT
Old Sep 28, 2020 | 12:34 PM
Wayno_san's Avatar
20 Year Member
Hi guys,
I need to change the rear brakes on my car (already purchased stock pads) and I also need to change and bleed the brake fluid. I plan to track it maybe once per year and I recall that there were issues with the stock fluid due to its low boiling point.
Any specific recommendations for this use-case? I'd prefer to avoid paying for any unusually-high priced "boutique" brand-names... just want something that will work as it should with perhaps some additional temp margin. Thanks!
ps: If there are any tricks to doing a manual brake fluid bleed I'd also appreciate any recommendations. I do not have any of the special bleed tools.
Old Sep 28, 2020 | 02:33 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I've been using the RoadStr app for some local drive events. Steep canyon roads + spirited driving on stock '04 sedan brakes = boiled my brakes a few weeks ago on a night run through some canyons. Our group stops at the bottom of that particular road to gather everyone up and my pedal went almost to the floor! I bled in Stoptech STR600 in with some help from my buddy; didn't touch the pads or rotors. Driving the same road during the daytime after the fresh fluid, the brake pedal got just a little soft, though still retained good braking response. Very happy! Might try STR660 when I upgrade my front calipers and all rotors to '05/06 spec.
Old Sep 28, 2020 | 03:26 PM
Wayno_san's Avatar
20 Year Member
I found that article where MotorTrend crashed the Nissan Z due to apparently the brake fluid boiling. They switched to ATE Super Blue which has a temp rating of 500+F.
Old Sep 29, 2020 | 10:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
ONLY use DOT3 fluid. That's pretty much the most important thing.
I prefer Valvoline synthetic.
buzzking
Jul 1, 2011 03:14 PM
gunjakill
Oct 2, 2008 05:36 PM
infinitig35cp6m
Aug 7, 2008 05:23 PM
longbutthair
May 6, 2008 01:43 AM
mikeee2
Apr 9, 2006 12:36 PM
