Uprev launch control?
Noob question I'm sure but I just got uprev and im wondering how to activate launch control throttle wise, im in the right map clutch down and in first but it just free revs. If anyone wants to pass along a tip it would be appreciated
Are you sure its turned on in the rom? You have the ARC license right?
You have to be at a complete stop, not even rolling backwards, and slam the gas, don't ease into it. If you have an aftermarket clutch that can screw with things too
Yeah I've got the license and its definitely on there since my tuner was doing it. I've got an upgraded clutch so maybe that's messing with it. Do you blip the gas and then floor it or just straight floor it in first with clutch in?
Personally I haven't gotten it to activate but LC is on my first map and it was activating on the dyno. I heard that you were supposed to blip then floor it but ill try just gassing it with no blip thanks!
Gotta have the clutch pressed in as well, can't just WOT in neutral to 2-step.
First gear, clutch FULLY depressed (has to see the clutch switch) WOT (has to see high enough voltage on the pedal) then the rpm's will hang at 3200.
If they don't then they either didn't turn on the ARC, or the clutch switch isn't seen, or the WOT voltage isn't seen.
Took me a few tries at first. No blip, you have to FLOOR it immediatly. Only potential issue is that the throttle voltage setting may be too high, basically it not recognizing WOT. I recall having to tweak the voltage setting for launch and no lift shift. Basically for me, the no lift voltage was too low so it would "stutter" on sprited driving that wasnt' exactly full out driving.
I also raise the disengage speed a few mph, but these are both things your tuner needs to take care of
How do you adjust WOT?? Is it just adjusting the screws?
billybrun
14
May 17, 2011 02:01 PM
