06 g35 overheating
Old May 12, 2021 | 01:23 AM
Matholland618's Avatar
06 g35 coupe
problem solved
Spoiler
Old May 13, 2021 | 12:32 PM
shurur's Avatar
2003 G35 Coupe
If you still hear gurgling and get overflow, make sure your hoses are all clamped. Otherwise, you are going to draw air into the system forever. My 2 cents.
Old May 13, 2021 | 12:39 PM
06 g35 coupe
problem solved.
Spoiler
Old May 13, 2021 | 04:48 PM
shurur's Avatar
2003 G35 Coupe
I ramp my car when I refill the coolant.
The 2003 has that fill T at the firewall.
Then I idle it up and watch the temp.
Shut it done and let it cool.
Then top off again if it overheated while on ramps.
Old May 29, 2021 | 10:31 AM
shurur's Avatar
2003 G35 Coupe
Originally Posted by Matholland618
problem solved.
So what was the final fix?
"problem solved" is not very specific and isn't going to help anyone who reads this thread in the future.
Good threads have follow-through or closure.
Old May 29, 2021 | 11:43 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
This was the problem. Timing chain guide above the water pump fell off and wedged itself between the chain and the pump. The chain then slid over the metal guide without engaging on the teeth of the water pump.
Old May 29, 2021 | 11:56 AM
cleric670's Avatar
BANNED!!!
Also, I went through and preserved all the original discussion that was edited out as SPOILERS in each post so it's preserved for folks for the future. First time I've heard of this problem so it will be a good reference in the future.
Old May 30, 2021 | 08:06 AM
shurur's Avatar
2003 G35 Coupe
Thanks!!!!!!!!!!
cizzla7049
May 16, 2021 09:40 PM
G35stephen
Jul 11, 2018 12:19 PM
rdozier
Jul 10, 2016 01:36 AM
Kevin K
Aug 3, 2015 10:30 PM
Excitedboutmyg
May 23, 2014 11:45 AM
