Some fluid leaking next to driver wheel
Old Jun 1, 2021 | 09:56 PM
koko's Avatar
G35 MT
The
se are the best photos I could get of the leak it’s a MT if that might help it looks like oil but is lighter than it kinda like a pee color and doesn’t smell like oil either
Old Jun 2, 2021 | 05:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is it actually an oil or is it just dripping condensation from the AC?
Old Jun 2, 2021 | 05:45 PM
koko's Avatar
G35 MT
it’s not condensation from the ac because it’s a pee like color and I have a feeling it’s clutch fluid
Old Jun 2, 2021 | 09:17 PM
cleric670's Avatar
BANNED!!!
Is your reservoir low? I doubt it's clutch fluid because it's a VERY small reservoir and doesn't take long to empty then you wouldn't be able to disengage the clutch.
Check all your reservoirs, clutch, brake, power steering. I suspect it's going to be power steering fluid because that's FAR more likely to leak.
Old Jun 2, 2021 | 10:26 PM
koko's Avatar
G35 MT
no it wasnt power steering thats all the way full couldnt tell if it was coolant because ive been low on it, but it probably isnt not brake fluid, and the clutch fluid is damn near empty but the clutch still works i still shift from 1st to 2nd to 3rd to N etc. i noticed this leak on 5/29/21 if that helps
Old Jun 2, 2021 | 10:33 PM
koko's Avatar
G35 MT
ok i double checked witha flashlight and im only low on coolant but there is still some there and im not having overheating problems the brake and clutch fluid is actually all the way full and the windshield wiper fluid i cant even see but it still sprays out of my wipers and the oil is fine so, car runs good i jus cant think of what it could be
JuicyJuice
Jun 18, 2018 01:32 PM
Halcyon777
Drivetrain
14
Apr 11, 2008 12:13 PM
Andrei
Drivetrain
Mar 3, 2008 12:20 AM
chinaman_87
Feb 23, 2007 05:16 PM
