Is my engine toast? Pls help :(
Old Jul 20, 2021 | 07:02 PM
Atjstballin's Avatar
G35 coupe 6mt
My car is making a weird rattling noise half the time I start it (more often when it's been sitting for awhile). But it only lasts like a 1 second everytime it happens then it's gone. Car still runs and pulls hard no weird noises. Please me guys
Old Jul 20, 2021 | 09:45 PM
Ponyryd's Avatar
G35x
Any oil in it?
Old Jul 20, 2021 | 11:39 PM
G35 coupe 6mt
Yeah the oil has never been below the l line usually around the middle and h
Originally Posted by Ponyryd
Any oil in it?
Yeah it's never been below the L. And wouldn't the car rattle on acceleration? It doesn't I'm just scared rn
Old Jul 21, 2021 | 07:23 AM
Ponyryd's Avatar
G35x
Probably nothing to worry about, might be a timing chain tensioner bleeding down oil or something. You could try a thicker grade of oil to see if it helps.
Old Jul 21, 2021 | 09:39 AM
G35 coupe 6mt
Isn't there something that I could replace like the tensioner or the chain? Will the chain break if I leave it for now? I still need a car for work.
Old Jul 22, 2021 | 07:50 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably just the timing chain tensioner getting worn, if you have over 100k on the motor I would change it. Mine used to make noise like that on startup as well and the chain tensioner made the issue quite a bit better.
The tensioner is driven by oil pressure, it takes a second for the oil pressure to build up in the system to really push on the guide when you first start the engine.
Does yours make that noise every time the engine is started or just when you start it cold in the morning, mine wasn't quite as bad and only made that sound on a cold engine.
Old Jul 22, 2021 | 08:40 PM
G35 coupe 6mt
It happens more often when it's cold, but when it's warm usually almost never get the sound. Do you suggest I just change the tensioner? There's a easy way to get to it I believe I just take off that front capsol.
Old Jul 23, 2021 | 09:10 AM
cleric670's Avatar
BANNED!!!
Yeah replaced it with an OEM Nissan tensioner, they're about $100. You take off a little access cover on the front of the timing chain cover to access it just make sure to follow the steps in the FSM because you have to rotate it a specific direction to get it out and DON'T DROP THE BOLTS into the timing chain cover...
Old Jul 23, 2021 | 10:44 AM
G35 coupe 6mt
got it, guess I'm making a trip to nissan/infinity. And what does fsm stand for? Forgive me for my lack of knowledge and thanks again 🙂
Old Jul 23, 2021 | 10:46 AM
cleric670's Avatar
BANNED!!!
Factory Service Manual, it will be in section EM - Engine Mechanical.
https://www.nicoclub.com/infiniti-service-manuals
Old Jul 23, 2021 | 10:47 AM
G35 coupe 6mt
Thank you Cleric!
Old Jul 26, 2021 | 02:24 PM
LoSt180's Avatar
Mine would rattle if oil was around the mid-point or lower. Try topping off the engine oil and see if that helps.
Old Jul 30, 2021 | 03:58 AM
LI-G35Driver's Avatar
I believe mine used to make that noise when it was lower on oil too...
Old Aug 6, 2021 | 06:35 AM
HeyZeus420's Avatar
2006 G35 coupe premium
I have owned Datsuns and Nissans, start up noise is not uncommon... But new noises always require checking the oil and normally they go away if you top it off
Jorgebarrera
Jan 25, 2016 02:42 PM
R6n350GT
Jun 11, 2015 06:51 AM
Footballmania32
Sep 18, 2014 01:32 AM
frog
May 11, 2008 07:38 PM
timElinE
Nov 30, 2007 09:06 PM
