Not sure where the fuel tank leak is!
Old Jul 31, 2021 | 06:35 PM
humbalum's Avatar
Infiniti G35 Coupe 2005 Gray
Unhappy Not sure where the fuel tank leak is!
Soo I purchased a g35 that already has a fuel tank leak, he provided me with a new tank. I was curious if I can locate the leak and patch it up for the time being until I have the time to either install the new tank myself or have a shop do it for me. He said it starts leaking just over a quarter tank and I currently have less than 10 litres in the tank. Should I keep filling gas into the tank until it starts leaking? What is the best approach I should take to this situation. Thanks
Old Jul 31, 2021 | 09:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Remove the back seat, there are two pull tabs right where the seat meets the carpet in the middle of each seat. Pull both to the front of the car and lift the cushion up at the front. Now there are two access panels, remove and see if it's leaking from the primary line.
If not then get the car up on jackstands and see where the fuel is coming from.
Old Aug 1, 2021 | 03:53 PM
humbalum's Avatar
soo here is what I got when I opened the access panels, since the leak isn’t coming from both access panels, should I just buy some gasoline so it leaks, and then I can find out the location of the leak under the car?
Old Aug 1, 2021 | 04:22 PM
cleric670's Avatar
BANNED!!!
Yep that's exactly what I would do.
M-azing.
Jan 24, 2009 08:37 AM
bestos02
May 15, 2008 08:29 PM
rraabb11
Feb 9, 2006 03:52 PM
CouperDouper
Jul 25, 2005 12:00 AM
