Driver side window problem
hi guys! I have a problem on my driver side window. I just changed window motor. I used reset button, but when I open the door window goes down, and when I close, it stays on that way, does not go up. + auto function does not work on up mode. if i push down, yes. it works.
what do you think? have you ever had this problem?
Sounds like you didn't perform the motor recalibration properly.
https://www.infinitihelp.com/diy/gco..._procedure.php
