Window Trouble
Old Sep 16, 2021 | 04:50 PM
OnemeanG's Avatar
Manual G coupe
Window Trouble
Got an 05 coupe. My window won’t begin rolling down or roll up without me helping it with my hand. After it’s rolled down a bit the button works, but to get it to started I need to push it downwards. It rolls upwards a bit but then it gets caught and I need to pull the window up. Also, every few times I close my door it drops a bit and creates a leak that I can hear at about 70mph. If I open and close the door enough times you can visually see a little gap from the outside. Drivers side is the only side I have a problem with
Old Sep 17, 2021 | 12:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Replied to your PM, probably the regulator and the motor both going back. Start by doing a good visual inspection to make sure none of the bolts are missing on the regulator though, if one backs out then it will pull the whole thing at a weird angle and bind it up.
Angler86
Mar 20, 2021 09:48 PM
mcosgrove
Interior
Mar 21, 2014 07:47 PM
Mr. Brett
May 14, 2012 01:03 PM
bukrickay
Jan 11, 2010 11:32 PM
ChuckP
Oct 12, 2006 02:39 PM
