2006 G35X lost power twice during long drive
Old Oct 12, 2021 | 02:14 PM
lrodptl's Avatar
My daughter came home from college and 90 minutes into her drive she lost ability to accelerate and got towed. We could not duplicate the problem and thought maybe she hit the shifter into manual accidentally. She just returned to college and approx 90 minutes into the drive she slowed down to 25 to pass through a toll booth and lost power when trying to reaccelerate.Engine would rev when accerator was pressed,but no power to wheels. She put the car into neutral and then back to drive and got it back. Any thoughts?
Old Oct 12, 2021 | 09:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check the transmission fluid level.
Old Oct 29, 2021 | 09:33 AM
shurur's Avatar
2003 G35 Coupe
Doesn't this sound like limp mode?
No mention of any panel lights...but...
Old Oct 29, 2021 | 11:55 AM
cleric670's Avatar
BANNED!!!
Not really because shifting to neutral then back to drive "fixed" the issue, if it was limp mode then you can only reset it by turning the ENGINE off and back on.
That's what makes me think this is a line pressure or torque converter issue. It also didn't throw a code for misalignment between the turbine input and output sensors though.
Plus actual limp mode (2k rpm limit and 5mph limit) doesn't cause the engine to rev freely without the corresponding power output, and your dash lights up like a christmas tree.
It's definitely possible the transmission just fell into neutral and she wasn't aware of it though, maybe the shifter just got bumped wrong and went into neutral without being FULLY pulled into the neutral gate, hence why she was still able to move the shifter further to the neutral gate then back to drive. It would have indicated on the dash what gear you were in though (it's controlled electronically not mechanically) and if it still said D while the engine could free-rev then there's a transmission issue of some kind.
Frankie Xenon
Jul 1, 2020 05:59 PM
graciousgeminii
Oct 27, 2018 03:32 PM
loko-moko
Jul 26, 2010 01:33 AM
Claude
Tuner & Dyno
Nov 16, 2009 06:22 PM
toca
Jan 26, 2006 11:51 AM
