Crank but not starting
Old Oct 14, 2021 | 10:11 PM
Sadamczyk23's Avatar
Infiniti G35 coupe
So my car went dead on the highway and after getting it home found it was the throttle body so that was replaced (and did pedal dances). After that having no luck I figured it was the cam sensors but still no luck, brought it to a mechanic and they said the fuel pump was bad so I changed that. I’m really stuck and not sure what it could be, thinking about checking for spark but not sure what my next step should be. -2006 G35 coupe Stock
Old Oct 14, 2021 | 11:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Plug in an OBD2 scanner and check for codes. Just because the SES light is not on doesn't mean there aren't codes
Just out of curiosity, when you crank the engine is the red NATS Security LED Solid Red?
blue g35
Jul 31, 2017 08:38 PM
Freetrade59
May 3, 2017 05:03 PM
ImPoppi
Jul 24, 2012 10:58 PM
1nickatnite1
Feb 19, 2010 11:41 PM
Skaterbasist
12
May 2, 2007 10:27 PM
