2004 infiniti g35 coupe grinding sound
Old Nov 4, 2021 | 03:26 AM
g35state808's Avatar
g35
Whenever i start driving there is always a single grinding noise that sounds like it comes from the driver side front wheel. Like it's a every morning thing, i move maybe 50 feet then grind then nothing else will happen for the rest of the drive. It's been happening every since I bought the car and I recently changed the caliper and brake pad in the front for that reason but it still happens. I heard it could be the abs self check but I am not sure.
Old Nov 4, 2021 | 10:10 AM
shurur's Avatar
2003 G35 Coupe
If it sounds something like noisy or knobby tires, it could be the front wheel bearings.
Old Nov 4, 2021 | 10:49 AM
g35
I thought so to so I changed the font wheel bearing too but the sound still happens
Old Nov 4, 2021 | 02:14 PM
Scorpi0's Avatar
Its the car testing the ABS system. It does it the first time u hit 10mph after a start.
Old Nov 4, 2021 | 02:24 PM
Scorpi0's Avatar
https://g35driver.com/forums/g35-cou...eck-sound.html
Old Nov 4, 2021 | 02:36 PM
Scorpi0's Avatar
From the manual
Old Nov 4, 2021 | 09:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep it's the motor on the ABS valve block, turns on for about 1/2 a second the first time you hit 10mph. It's one of those things that's hard to unsee once you are aware of it
Magneu
Oct 22, 2018 08:55 AM
jaymak
Aug 15, 2017 02:13 PM
dunstopnow
Jul 9, 2012 02:31 PM
blownvert
Apr 29, 2012 08:04 AM
niu
Drivetrain
Mar 20, 2005 01:27 AM
