Instrument cluster repair
Old Nov 20, 2021 | 08:27 PM
Jcampus's Avatar
2006 G35x sedan
Does anyone know of a place in the Chicago land area that does instrument cluster repairs?
Old Nov 21, 2021 | 02:56 AM
Scorpi0's Avatar
Whats wrong with it?
Old Nov 21, 2021 | 09:10 AM
Jcampus's Avatar
2006 G35x sedan
Fuel gage not reading properly. Have a P0462 code (Fuel level Sensor Circuit Low Input, which means the fuel level sensor is no longer taking correct readings) and based on the research I’ve done it seems that the cluster needs to be repaired. I already replaced both sending units with no change. The gage never travels below 1/2 a tank. 1/2 is empty. Any thoughts?
Old Nov 21, 2021 | 09:24 AM
Scorpi0's Avatar
U can try to repair it yourself if youre ok with electronics. Check out the pictures on page 5: https://g35driver.com/forums/g35-sed...etailed-5.html
Old Nov 21, 2021 | 10:28 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Measure resistance across pins 2 and 5 on the pump, 1 and 2 on the sub pump. Make sure they are actually sending the correct resistance from full to empty.
Typically that code means an issue with the floats themselves or the WIRING, not data being interpreted by the cluster wrong.
Old Jan 7, 2022 | 10:55 AM
alidonkaka6's Avatar
bmw m3 i like alot blue color
Moderator EDIT: Banned for botting
Old Jan 7, 2022 | 04:03 PM
Jcampus's Avatar
2006 G35x sedan
I have the same problem. Based on my research you need to have the instrument cluster repaired. I live in Chicago and the only place I can find is in Wisconsin. Tania auto electric
Old Jan 8, 2022 | 03:21 AM
909's Avatar
909
Your mom's boyfriend
Looks so easy, literally a few resistors in red.
OP any laptop repair shop / electronics repair shop can do this.
Or buy a soldering iron and do it yourself.
Old Jan 8, 2022 | 03:58 AM
Scorpi0's Avatar
The tricky part is getting the indicator needles off, and then installing them in the correct position during reassembly.
Old Jan 8, 2022 | 10:27 AM
cleric670's Avatar
BANNED!!!
Just put the instrument cluster into test mode first and mark locations, put tape behind the needle and make a mark on the tape exactly where the needle lines up. Do this for all the gauges. When your repair is finished, put the cluster back in test mode again and install the needles.
You will need to remove the clear plastic cover from the instrumentation to do it, and make sure you use some kind of tape that won't accidentally peel off, yellow or orange 3M Super 33+ electrical tape works perfect.
Old Jan 8, 2022 | 03:35 PM
Scorpi0's Avatar
I just took a picture of the cluster in test mode before I took it apart
Old Feb 8, 2022 | 04:02 AM
burkenelsonabel's Avatar
Moderator EDIT: Probably a bot, not waiting for the edit with malicious links.
Old Feb 8, 2022 | 06:03 AM
Scorpi0's Avatar
Originally Posted by burkenelsonabel
hello
I'm having the same issue. According to my investigation, the instrument cluster has to be fixed. I reside in Chicago, and Wisconsin is the only location I can locate. Tania is an electric vehicle.
Is this a bot using AI to pick up words from this thread?? 🤔
Old Feb 8, 2022 | 10:33 AM
G2B35AGN's Avatar
"Join Date: Feb 2022
"Posts: 1
"bmw m3 i like alot blue color"
Old Feb 8, 2022 | 10:41 AM
cleric670's Avatar
BANNED!!!
Yeah it's a bot, just keep using the report post function so I can get on it early. Yes you have spotted the pattern too...
