speedometer off a bit and manual mod not working, aftermarket wheels or cluster?
Old Mar 16, 2022 | 04:33 AM
Kadedavis4's Avatar
G35 coupe, red
so the thing I was already looking to fix was the manual mode, and I'm mostly seeing people say gauge cluster. The cluster was replaced pretty recently, and when it got replaced i also noticed that the speedo showed about 10% under the actual speed, so 45 on the dash is roughly 50. The thing is, my wheels aren't stock. they are both 19' which should be stock for me, but I don't know what size they were before. also, my tires have a bigger diameter than stock. This is what I assumed the speedo being off was. Could it also make the sensors freak out and shut off manual mode? or could the cluster be the problem for both issues? I wasn't the one who replaced the cluster, and I've heard that if the specs are off by even a little bit it can mess with the system.
Old Mar 18, 2022 | 12:15 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Exactly what size tires do you have on the rear?
Old Mar 19, 2022 | 02:09 AM
Kadedavis4's Avatar
G35 coupe, red
the rear tires are 275/45ZR-19, so about 124 mm or 4.87 inches
Old Mar 19, 2022 | 03:25 AM
Scorpi0's Avatar
Having bigger tires will actually show u a slower speed indication, but one inch bigger shouldnt make much difference. U can always remove the speedo indicator needle
and set it back on slightly higher than its current position.
Old Mar 19, 2022 | 10:19 AM
cleric670's Avatar
BANNED!!!
It's off by 7.5% so the stuff you posted sounds like everything is functioning as expected when running that tire size.
Chilli
Jan 25, 2022 08:52 AM
pl_G35
Mar 11, 2010 03:29 PM
jlinares
Apr 23, 2009 04:03 PM
BrendanS
Feb 9, 2008 06:55 PM
