Rattle under load 2004 350Z 6MT VQ35DE
Old Jul 1, 2022 | 12:49 AM
2004-350Z-sand's Avatar
nisaan 350Z 6MT enthusiast
Engine bay rattle under load 2004 350Z 6MT
Hey all it’s me back again with my stupid rattle issue on my 2004 350Z 6MT. I’ve done some more digging and this is what I’ve found.
It’s and intermittent rattle from what I believe is the engine bay when under load from 2500-3000 rpm.
We’ve determined it only occurs when the car is up to temperature and NOT when cold.
We cannot reproduce the sound in neutral by revving the motor.
There is no rattle upon cold start from the engine like videos have shown online about the primary tensioner being bad
My mechanic was super busy when he had my car so didn’t have too much time to look into the car however he pulled my spark plugs and said they looked good as well as having hooked his scanner up to the car and said when the noise occurs the car is not pulling/retarding timing at all. Car does have the correct oil pressure according to my gauge when under load and the oil has never ever dropped as I constantly check it daily (yes I know I’m a bit overkill when it comes to this).
Car is bone stock motor wise apart from a k&n cold air intake and throttle body spacer which came on the car.
This is a similar video which I have found on YouTube of a g35 having the same issue with no resolution.
Any help would be greatly appreciated thanks all!
https://youtu.be/enBgYrVyE2Y
Old Jul 3, 2022 | 11:13 AM
2003G35stock's Avatar
G35 Manual
In that video, it sounds a lot like a heat shield rattling, that might explain why it only happens when warm. The last one I heard like that, it was a heat shield around the catalytic converter. I took a couple of hose clamps, stretched it all around the cat, and that stopped the sound.
You could also get a metal wire tie wrap, if you have those.
Anyway, that's my first guess.
2004-350Z-sand
Jun 16, 2022 10:52 PM
2004-350Z-sand
Jun 11, 2022 12:52 PM
G35_HKS
Jan 21, 2017 01:14 AM
Fretwise
Jan 26, 2011 12:57 AM
