What is this on the back of the engine?
Old Jul 17, 2022 | 02:52 AM
2003G35stock's Avatar
G35 Manual
Hello all, as I've been writing, I'm fixing a leak on the rear main seal. Well, there is another item that looks like it might be leaking, but I can't figure out what it is. It's at the top of the back of the engine, seems like a plug, but really not sure. Don't recall seeing this on other cars,so I thought I would ask, in case I need another gasket.
So, what is this? Looks like you can fit a torx into it. Right there, center stage of the pic, above the crank.
Old Jul 17, 2022 | 10:48 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Coolant jacket plug, there's two smaller ones on the left and right side of the block as well.
I've never seen them leak coolant ever though.
Old Jul 17, 2022 | 11:59 AM
G35 Manual
Hmmm...there is oil around it, maybe it was simply flung up there by the rear main seal leak.
I won't worry then, thanks! Obviously then no oil can be coming out of it.
Old Jul 17, 2022 | 04:39 PM
cleric670's Avatar
BANNED!!!
Probably came from the valve cover gaskets above it.
Old Jul 18, 2022 | 12:39 AM
G35 Manual
makes sense, thanks.
Old Sep 14, 2024 | 11:03 AM
HoserG35's Avatar
G35 6MT “Brembo Car”
Just a heads up to anybody that stumbles across this thread in the future, that plug is for the oil galley that runs from the front to the back of the engine and down to the bearings. It’s not for coolant.
lilsLb88
Jul 2, 2022 09:23 AM
otreytrey
Dec 5, 2021 11:07 AM
G35,6MT
Feb 6, 2010 01:57 AM
calesa1
Dec 10, 2006 08:24 PM
