Going under the knife for her third time…
Old Nov 1, 2022 | 09:36 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by jdlynch
No navigation. j just have the Bose radio. So far the CD player has already quit on the factory HU.
You might be able to get away with bolting the screen mount directly to the inside of the cubby lid with it permanently being open. I don't have a non-nav G35 anymore, so I can't check, but you might be able to basically just drop the control box for the new radio into the cubby, cut holes for wiring in the back, and make a replacement "lid" that acts as a bracket for the new screen.
It'd be possible to 3D print a complete cubby replacement with the single-din mounting holes and such to make it a drop-in replacement, but I don't have a cubby to use for measurements here. If anyone has one to donate, I could do all the 3D modeling and printing here.
Old Nov 2, 2022 | 01:22 PM
jdlynch's Avatar
You are so awesome so offer your help! At this point, I am in discussion with a local radio repair shop that's aware of the failure mode of the g35 HU. I may have them repair and add-on a Bluetooth interface. This would be the easiest and least expensive option.
Old Nov 10, 2022 | 12:30 PM
JZ39's Avatar
I know you probably can’t tell how well the paint job came out from this picture, but it turned out great.
Old Nov 10, 2022 | 12:38 PM
JZ39's Avatar
Have a bunch of goodies going on today:
Differential bushings
370Z axels
Front and rear wheel hubs
One piece aluminum driveshaft
Stainless brake lines
Differential brace
Can barely wait.
Old Nov 10, 2022 | 12:39 PM
JZ39's Avatar
These things are pretty!
Old Nov 10, 2022 | 03:34 PM
G2B35AGN's Avatar
Golly. Did you have to follow the golf club instructions to get all that stuff in the trunk?
Old Nov 10, 2022 | 05:15 PM
JZ39's Avatar
Lol. Most of the space is taken up by my oem car cover. I keep that in there in the event of hail
Old Nov 14, 2022 | 05:20 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
It looks great! Congrats.
Old Nov 20, 2022 | 09:53 AM
JZ39's Avatar
Quick update. All of the work is done with the exception to getting new high flow Kinetix cats installed. Not terribly unexpected, but one of the bolts on the stock cats broke while removing the exhaust so I had to order new ones from Z1. I’m almost glad that this happened because the stock cats looked like crap all rusted and this mod will hopefully provide a little extra fun in the hp department along with the driveshaft.
Probably won’t get the car back until after Thanksgiving at this point due to shipping etc, but can’t wait to get behind the wheel. I really need to get new tires in spring as well. My Contis have a lot of tread left, but they are certainly hard from time and don’t grip well anymore. Will do Sport 4S in spring.
Old Nov 21, 2022 | 04:52 PM
20 Year Member
I'm curious to see how the Kinetix HFCs work out for you as I've been looking at them as well. Some of the other brands seem to be more susceptible to causing a CEL and I don't feel like dealing with that.
Old Nov 21, 2022 | 09:14 PM
JZ39's Avatar
I really hope I don’t run into a CEL - Kinetix claims they don’t. I am replacing the O2 sensors with oem at the same time in the event that this could be the culprit of any unexpected CELs, as O2 sensors are notoriously sensitive to being fooled with in my experiences.
This project has definitely gotten larger than originally anticipated…..
Old Nov 24, 2022 | 01:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You could always just plan on running non-foulers from the start instead of waiting for the CEL to turn on then installing a set.
Silver tiburon
Apr 7, 2012 04:36 AM
9600baud
Picture Share
29
Sep 4, 2009 04:09 PM
penelson
Northern California
Sep 28, 2008 09:41 PM
16psibrick
Jul 16, 2006 11:50 PM
realgone
Jun 21, 2005 12:57 PM
