Best clutch and flywheel kit for my ‘07 g35 Rev up
Old Sep 25, 2022 | 08:18 AM
mqcah's Avatar
Infiniti g35, de rev up
Hey so my g35 clutch has been rattling ever since i got it, it appears to be the throwout bearing because everytime i depress the clutch the clattering goes away and starts once i release it. replacing the throwout bearing isn’t cheap because of labor, so i was thinking i should just replace the whole clutch while i’m at it since i have about 134k and i don’t know if it’s ever been done. Do any of you know what clutch and flywheel kit is the best for its price? I don’t need to do the flywheel but am thinking about a lightweight one. Thanks!
Old Sep 25, 2022 | 10:48 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I went with the Z1 Motorsports lightweight kit because I don't mind chatter and love the way it revs out on a light flywheel.
Old Sep 26, 2022 | 10:57 AM
2003G35stock's Avatar
G35 Manual
If you don't replace the flywheel, at least resurface it before putting it back on. And make sure to check closely when you put it on that it is clocked correctly. You will see (unless it's fallen out) a very small dowel pin to line up the flywheel correctly.
Old Sep 27, 2022 | 06:59 PM
cleric670's Avatar
BANNED!!!
It's hard to find a shop that will even attempt to resurface a dual mass flywheel. Usually what fails is the return springs, then the center section just flops back and forth against it's bumpers.
I've paid guys under the table to just do it anyways, I tack welded the thing into place then ground the tack off later when I got it back. Porsche parts are stupidly expensive and sometime you NEED to just fix the part.
ZSpeedPerformance
Engine-Vendor
Nov 10, 2015 11:16 AM
Simpson79
Drivetrain
Jun 1, 2015 11:51 PM
SkylineR-34
Oct 18, 2011 10:58 AM
gcode
Jan 3, 2010 01:44 PM
