Help??! How to get coolant hose off the connection?
Old Sep 30, 2022 | 06:35 PM
LI-G35Driver's Avatar
As mentioned 2 weeks ago I cut the coolant hose trying to replace the bleeder valve (heating hose I think is the correct term since this is the hose that goes from the bleeder into the firewall) I literally have the hose cut open in half at the firewall, clamp is off the hose and it will not come off the connection that is in the firewall. I can put my finger in and feel the hose around the connection at the firewall but that hose will not come off! I am trying to put the new replacement hose onto the connection at the firewall but can not get the broken one off the connection at the firewall. Its like its cemented on or something. Is there a spray I can spray on that will soften the hose or something. Something so I can manipulate it off. I tried fitting a knife back to their to slice the hose around the connection to peel it off but cant seem to get a good angle to cut into it. Its cramped. Any tricks? Any special tools? lol.
Old Sep 30, 2022 | 06:50 PM
Ok.. I see some saying a heat gun if you can fit it back there and a pick also. Just ordered a pick to see if the angle can fit and get back there to pry. Any other tricks anyone know of? There should be some kind of liquid you can spray to help manipulate the rubber.
Old Oct 1, 2022 | 10:05 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just grab the hose with a pair of channel lock pliers and start gently twisting, don't clamp down enough that it damages the heater core stub but you'll start to twist the rubber hose back and forth and eventually all that corroded crap will break free.
Since you already put a slice in it you could grab the edge with some long reach needle nose pliers and start twisting that way as well.
Coolant hoses are always glued into place basically and can be a pain to remove.
LI-G35Driver
Sep 17, 2022 12:59 PM
shurur
Dec 31, 2021 07:22 PM
Lil_Spanish
Jan 19, 2020 11:32 PM
Salim Amrani
Nov 18, 2017 07:41 PM
FLFIRE
Mar 20, 2005 02:00 AM
