2003 G35 cam
Call Z1 Motorsports and ask them, there's only a few options for cams on the VQ35DE.
If I had to just GUESS I'd say probably the JWT C2 cams (doesn't necessarily require their springs but it's strongly recommended) would probably be a good match for the greddy twins and not too obnoxious on the brakes.
The C8 or C9 are too aggressive imo, track use only and the REQUIRE the JWT springs. Your brakes will suck, you will be adding a vacuum can. They do sound absolutely badass at idle though
You will have all the typical big cam issues with something this big though, I think the C8 is like 272 and the C9 is 282 or so.
If you do want one of those really aggressive cams don't get the C9 if you drive this thing as a daily driver, bigger is not always better.
You will have all the typical big cam issues with something this big though, I think the C8 is like 272 and the C9 is 282 or so.If you do want one of those really aggressive cams don't get the C9 if you drive this thing as a daily driver, bigger is not always better.
So the JWT C series cams are all their race cams, they get progressively more aggressive the higher the number, that's why I was thinking the C2 would probably be a good fit. Definitely call Z1 Motorsports and talk to them (or CZP, ZSpeed, etc) these shops SPECIALIZE in the G/Z and will be able to give better recommendations when you tell them exactly what you're trying to do with the car. You can also talk directly to the manufacturers like someone suggested in another thread you were in.
The reason I would talk to the vendors and not the manufacturer is it sounds like you're going to be getting an entire package, cams, rods, pistons, springs, oil pump, etc. The vendors are almost certainly who you're going to be getting stuff from so you will usually get a better deal just letting them bundle together a package for you.
You need to clarify ..
You Said your tt but you're rebuilding with fbo... so that's na...
Might want to clarify which step you're currently at. So we can assist you better.
You can have an unmodded FI or a FBO FI. Huge difference in power too, if you're stock exhaust and zero mods except with a Vortech you are making maybe 320whp or so, FBO you'll make more than enough to bend rods. Same thing with turbo except the base unmodded numbers will typically be a little higher, depends on the compressor. Plus you end up pushing so much boost just to make power that your volumetric efficiency is garbage compared a turbo engine with lower compression. You'll make a lot of heat
but not a lot of power.
