View Poll Results: What should I do
I dont know
0%
What’s the next step
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2007 g35 coupe crank no start
Old Jul 18, 2023 | 11:48 PM
Vq_Ghost's Avatar
G35
Hello so I’m having problems with my g35, I have switch out my cam and crank shaft sensor and I change out my starter and fuel pump I changed out my fuel injectors and fuel rail and I changed out my spark plugs. & nothing I also changed out my ipdm and nothing I don’t know what else to do! Please help me!
Old Jul 20, 2023 | 04:39 PM
Urbanengineer's Avatar
Is it throwing codes you can check with OBD?
Old Jul 20, 2023 | 07:06 PM
Vq_Ghost's Avatar
G35
Just p0102 and I did have one for the throttle body but not anymore.
Old Jul 20, 2023 | 07:24 PM
vq_corpse's Avatar
2004 g35 6mt
G35 same issue
why am I having the same issue as you bro this sucksss, I literally did everything you did already
Old Jul 20, 2023 | 07:37 PM
vq_corpse's Avatar
2004 g35 6mt
if you ever find the problem man shoot me a holler, but if I find the issue ima shoot you a holler
Old Jul 20, 2023 | 09:30 PM
Vq_Ghost's Avatar
G35
i will but at the moment I spent so much money I have to wait for awhile lol. It was running good and out of no where didn’t wanted to crank anymore so I changed out the battery and nothing I changed out the starter and nothing and than I thought It was a fuel problem I changed out the fuel pump and nothing and than I changed out the fuel injectors and fuel rail I change out the spark plugs and nothing I thought it was the ipdm and nothing I’m so done with it at this moment! I really need help! Each time I spray the starting fluid in the throttle it runs for like 10 secs and slowly just stops
Old Jul 20, 2023 | 09:33 PM
vq_corpse's Avatar
2004 g35 6mt
bro if it starts for 10 secs and dies you’ll have to head into the fuel category most definitely. Because you definitely have spark . Like in my situation I sprayed in it and it doesn’t turn on so I have an electrical or spark problem. Check your whole fuel system, hook a fuel pressure gauge to it and see if that’s the culprit.
Old Jul 20, 2023 | 09:35 PM
vq_corpse's Avatar
2004 g35 6mt
If you take the fuel bezel off does fuel come spraying out? When you take a spark plug out is it wet and reeks of fuel?
Old Jul 20, 2023 | 09:48 PM
Vq_Ghost's Avatar
G35
what fuel bezel? & no it wasn’t recking like fuel tho
Old Jul 20, 2023 | 09:52 PM
vq_corpse's Avatar
2004 g35 6mt
that thing? Take the 2 10mm off and gently pull off cover your face and everything but see if fuel come out aggressively if it doesn’t you have a pressure issue. Be very detailed about how the fuel came out when you reply, also you mentioned the spark plugs aren’t wet, that totally heads into fuel pressure.
Old Jul 20, 2023 | 10:20 PM
Vq_Ghost's Avatar
G35
I did take it off! & it does have fuel!
Old Jul 21, 2023 | 12:20 AM
vq_corpse's Avatar
2004 g35 6mt
did it feel pressurized if so how much? if anything the injectors are probably not firing, crank the vehicle real quick and pull a plug to see if it’s wet again
Old Jul 22, 2023 | 12:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Z1 Motorsports sells a sandwich adapter you can put under that fuel damper which allows you to hook up a fuel pressure gauge.
Old Jul 22, 2023 | 12:12 PM
cleric670's Avatar
BANNED!!!
Also, if you're throwing P0102 you have a MAF issue. I'd replace it with a Hitachi one because a bad MAF can cause a fail to start (not fail to crank).
EDIT: Or just unplug the MAF and see if the engine starts.
Old Jul 24, 2023 | 04:30 PM
Vq_Ghost's Avatar
G35
So I just realized there is no fuel pressure what should I do?
