Slow acceleration, oil on plugs
Old Jul 25, 2023 | 03:23 PM
IBurnOil's Avatar
G35 6spd coupe
Hey everyone,
Its my first time here so i appreciate any help i can get. I have an 04 6spd coupe that I've had for a few months now. Bought it with bad knock sensor harness and after fixing it it ran great. Now it's feeling sluggish. Pulled the plugs and changed them and found oil on the threads. Since then I've been watching my oil consumption it hasn't been that bad. I also feel like I have poor acceleration. If I'm in 1st and I mash the throttle the rears won't even burn out like they used to (If I modulate the clutch they still burn). Any ideas what it could be? No codes on the dash and my obd2 scanner doesn't show anything or have any pending codes. Need help!!
Old Jul 27, 2023 | 10:20 AM
Urbanengineer's Avatar
Was oil in the spark plug tubes, or on the spark plug threads to clarify where the issue might be.
Also - are all 6 cylinders firing like normal?
Old Jul 27, 2023 | 11:47 AM
IBurnOil's Avatar
G35 6spd coupe
Doesn't seem like any cylinder is misfiring based on the way it drives. An inspection of the old spark plugs doesn't give any indications of misfire either. The oil was on the threads of the plug. It's strange because there was a little bit of oil in the tubes (likely valve cover gasket) but I don't think that would cause oil on the threads. The plugs did seem like they were too loose for spec, so maybe that let oil seep past the seal from the top where it was leaking from the tubes? Definitely wasn't a big leak in the tubes tho and there was lots of oil on the threads.
socramiesreal13
May 16, 2014 05:00 PM
Pure350GT
19
Jan 2, 2014 06:44 AM
Ronjon17
Intake & Exhaust
Apr 6, 2011 12:27 PM
Project
Dec 19, 2008 02:45 PM
