Overheating problem
Old Dec 6, 2023 | 11:25 PM
camstill999's Avatar
Light blue coupe with sebring exhaust, plenum spacer and z1 intake
Overheating problem
So here’s my problem, i’ve gone through 2 radiators now. The first one cracked after i drove it stupid, the second one got a hole drilled through it. After I put the new radiator in it was still overheating but it took a while to get there. it got worse so I thought it was the thermostat, replaced it and the overheating problem is still there, just slightly better. Realized my radiator fans weren’t turning on. just replaced them today, they’re running fine. full on coolant, bled the system to the best of my knowledge and ability. It’s still overheating. My heat also doesn’t work, and i don’t know what’s causing it. The only things i can think of is it’s not an OEM radiator, and maybe my water pump. I have 2 days to figure this s*** out. someone please help me
Old Dec 29, 2023 | 05:06 PM
shurur's Avatar
2003 G35 Coupe
Hope you figured it out.
If heat is not working, you likely still have air in the system...namely the heater core.
Super common problem.
vkomatre
Nov 6, 2022 06:01 PM
charmer37
Feb 12, 2019 04:57 PM
TridactylZero
Mar 1, 2017 07:03 AM
OSKIRE
Dec 18, 2013 10:11 PM
digitalgulby
Jun 12, 2011 01:41 PM
