G35 Overheating issues
Old Sep 22, 2012 | 06:43 PM
vkomatre's Avatar
Hi,
Not sure if there is a thread already floating around for this issue I'm having, if it does can someone point me to it. This is what I have, I saw a thread for the exact same problem I have but didn't find a solution.
I got a 2003 G35 with 115K miles. Engine overheating issues, replaced a cracked radiator, thermostat. The temperature cold/hot indication was normal (in middle) when idle however when I drive it around the needle goes to hot quickly. Not sure if there is a problem with water pump, hoses, gasket, belts. I'm seeing too many advises but just wondering if anyone ran into the same problem I have and was able to fix it without too much trial and error.
Please HELP!!!!
Old Sep 22, 2012 | 09:43 PM
5150DS's Avatar
Most likely air in you cooling system. You need to burp the system to get the air out. Did you also replace the radiator cap? If not, I would.
Old Sep 22, 2012 | 10:52 PM
Ye_Budyy's Avatar
I had the same problem...one, are you losing coolant, or do you see any coolant leaking anywhere? (leaking coolant would be an indication of bad waterpump) but our cars don't really have bad water pumps.
When your car is idle at normal temp check the top radiator hose, then check the bottom radiator hose...they should
Be the same temperature. If bottom hose is not as hot thermostat is no good
I had that problem, I changed the thermostat and car was still running hot...got another thermo and then it was fine. Make sure you get the oem t-stat from the dealer.
And then when pouring coolant make sure you use the bleeder screw which is located close to the battery.
Old Sep 23, 2012 | 04:14 PM
vkomatre's Avatar
Thanks folks. I'll try that and see if it works out.
Old Sep 23, 2012 | 08:22 PM
Eric@TCGMiami's Avatar
Search my threads....
Old Sep 23, 2012 | 08:23 PM
3 possibilities
Headgasket
Air
Fan clutch
Old Sep 24, 2012 | 04:13 PM
vkomatre's Avatar
Did a temporary fix. Apparently the water pump is weak and hence the overheating issues even with new radiator and thermostat. So took out the thermostat and the overheating issue went away. At some point in the next few days, plan to replace the water pump and hope this is the final fix. Thank you everybody for your help.
Old Oct 2, 2012 | 08:19 AM
nfortier's Avatar
i have a 2003 g coupe. im having close to the same issue. radiator cracked and got tranny fluid all in it. replaced radiator but not the thermostat. been flushing the system out but the car is over heating now. heat comes and goes and the car doesnt overheat when it is idleing. I thought that there could be a air bubble in it but it hasnt fixed itself yet. the top hose gets hot but the bottom hose is cooler. I havent seen anything in the oil yet. if the thermostat was bad, wouldnt it not have heat at all? im pulling my hair out with this issue. Also i didnt replace the cap and it goes on hard.
Old Oct 2, 2012 | 08:23 AM
nfortier's Avatar
there is still tranny fluid in it but not to the level it was when it first happened. now its like a pimkish/whiteish jelly. small particles and everytime i flush it, it gets better. is there a solution i should be using as well and another thing is i was told about it possibly having a air bubble. how does that blow itself out? im new to this so the help would be greatly appreciated
Old Nov 6, 2022 | 01:30 PM
debjudy777's Avatar
Infinity g35
Overheating
hi I have changed the radiator, water pump and thermostat . Car is still over heating cause the thermostat isn’t opening help . 2003 g35 infinity
Old Nov 6, 2022 | 06:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pressure test the coolant system, if it isn't holding pressure it's not working.
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
