Need help
Old Jun 14, 2024 | 09:13 PM
manuels04's Avatar
G35 COUPE
Need help
My throttle body went bad and ordered a new one and installed it today and went and took a ride to feel how the new throttle Body was it was fine but after I Parked and turn off the car took a look at my tire a seen smoke only if you get close you’ll see it not from far away opened the hood and threw water on it and after that I start up and started up fine but took a look at the bottom and seen this 😞😭
Old Jun 16, 2024 | 05:30 AM
Scorpi0's Avatar
Huh? What are we lookin at?
Old Jun 17, 2024 | 07:13 PM
manuels04's Avatar
G35 COUPE
Bottom where the motor mount is located by the pulley
Old Jun 18, 2024 | 08:58 AM
Jemeu's Avatar
Some mods
Is that coolant? If it is, did you forget to hook your coolant line back up to your throttle body? The smoke can be from coolant getting on your headers just don't get any on your belts.
Also, the FSM recommends you perform the throttle body closed position procedure after disconnecting the throttle body. The idle air volume learning procedure after replacing the throttle body
There are YouTube videos that walk you through it, but I'll leave some pages from the FSM to perform the procedure.
This is from the FSM page EC-79, EC-80
Old Jun 18, 2024 | 11:59 PM
Polishthrust's Avatar
What is the ziptie for?
Old Jun 19, 2024 | 12:02 AM
Scorpi0's Avatar
More horsepower
03XG35
Feb 7, 2017 07:02 PM
idahir huerta
Jan 18, 2017 03:40 PM
Cabos G35 Coupe
Intake & Exhaust
44
Apr 28, 2012 01:05 AM
eddystone
Canada
11
Apr 21, 2011 01:56 AM
ilyaat
Oct 4, 2006 01:53 PM
