Car only cranks after transmission replacement
Old Oct 10, 2024 | 09:29 PM
mparham180's Avatar
Grey G35 Coupe
After replacing transmission car only cranks
my ecu was sent off and tested and came back fine
car has fuel pressure but isn’t getting any fuel at all
key was reprogrammed
sparkplugs and coil packs was tested and replaced but still no spark either
battery was charged
idpm was tested in a friends car and his started right up
so at this point I’m confused
Also we checked both tcm from both transmissions
Old Oct 10, 2024 | 11:07 PM
Urbanengineer's Avatar
Is it auto or manual?
was the flywheel replaced? https://my350z.com/forum/2003-2009-n...nit-start.html
Old Oct 10, 2024 | 11:09 PM
mparham180's Avatar
Grey G35 Coupe
it’s a auto
Old Oct 10, 2024 | 11:12 PM
It’s definitely not that then . Crank sensor tests good?
Old Oct 10, 2024 | 11:13 PM
mparham180's Avatar
Grey G35 Coupe
yea I forgot to mention it was one of the first things I did
Old Oct 10, 2024 | 11:16 PM
No fuel for sure? Did you camera cyl or how do you know?
check cam rear sensors too.
Old Oct 10, 2024 | 11:22 PM
mparham180's Avatar
Grey G35 Coupe
yea we pulled the fuel rail and fuel was all over the place and we swapped the sensors with my friend 350z
Old Oct 10, 2024 | 11:23 PM
Last question before I head to bed, but is the security light on while cranking? Won’t start if so.
Old Oct 10, 2024 | 11:25 PM
mparham180's Avatar
Grey G35 Coupe
it was at first but we reprogrammed the key I’m at a stump with this
Old Oct 10, 2024 | 11:26 PM
Good luck man. Sorry I couldn’t help.
mparham180's Avatar
Grey G35 Coupe
it’s all good man appreciate it tho
Touge_All_Day
Jan 6, 2020 06:19 PM
Luvans Delien
Feb 9, 2018 08:00 AM
99zx2turd
Mar 5, 2017 01:22 PM
btran35
Nov 25, 2014 03:51 AM
STARMAN
Forced Induction
May 25, 2007 02:16 PM
